How to remove the headlight clear guard from a RG?
Old 03-11-2012 | 01:46 PM
marvo75's Avatar
marvo75
Default How to remove the headlight clear guard from a RG?
I need to remove the clear headlight guard to clean inside it, how does this damn thing come off!?
Old 03-11-2012 | 02:10 PM
pittz5's Avatar
pittz5
should just pop off. Small screw driver may help. stick it in on bottom side and pry it off.
Old 03-11-2012 | 02:12 PM
Gearhead3's Avatar
Gearhead3
It just snaps into place. It's kinda scary the first time you take it off because you feel as if it's going to break, but it doesn't. Use something that won't mar the surface and just pry.
Old 03-11-2012 | 02:39 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Look for the 4 tabs. Use a butter knife with tape on it to protect the paint to unhook the tabs.
Old 03-11-2012 | 02:47 PM
DanDman's Avatar
DanDman
I used a plastic putty knive.
Old 03-11-2012 | 04:38 PM
rlaf75's Avatar
rlaf75
What he said
Old 03-11-2012 | 04:55 PM
longrides's Avatar
longrides
I've never taken it off without removing the outer fairing. Used a flat blade screwdriver and covered the end with elec tape and pushed the tabs out. I guess others have done it from the outside.
Old 03-11-2012 | 08:30 PM
marvo75's Avatar
marvo75
ty for the info, butter knife and some tape for the end of it, she popped right off...top then bottom...Damn thing probably never been off...My headlights are way brighter,thats how dirty it was!!
Wheelup
2014-2023 Touring Models
12-10-2016 05:56 PM
sharkey
08-15-2015 07:29 AM
Glide2001
04-26-2013 09:32 PM
Tweeter2148
10-10-2011 07:29 AM
alissa74
11-07-2007 08:43 AM
Quick Reply: How to remove the headlight clear guard from a RG?
