Another Tire Question?
Old 03-11-2012 | 01:17 PM
SugsPa's Avatar
SugsPa
Default Another Tire Question?
I'm getting ready to buy a new rear tire, and currently am running a stock size tire (MU90B16), Dunlop E-3. I would like to run a bigger tire, such as the 160/80-16. Does anyone know if a 160 size tire will fit on an 07 Ultra Classic? I'm thinking it has 3 inch rims.
Thanks,
SugsPa
Old 03-12-2012 | 07:12 AM
grbrown's Avatar
grbrown
The widest tyre a 3" rim will take is a 150/80, which compares with the 140/85 that your MU is. I have one with an 07 rear end in my 1990 Glide, with the narrow belt your bike has, so it should fit with no problems. It is not wise IMHO to fit a wider tyre to your stock wheel.
I do have however a Deuce rear wheel I plan trying to fit! It is 4.5" x 17" and will take a 160/70 or 170/60 tyre. I don't reckon a 170 will fit the bike, but I have my fingers crossed that a 160 will just squeak in! I reckon tyre to belt clearance will be close, as also will fender clearance. Those are the things that will make or break.
There is a thread on HDF about doing this, by Rodman, although he modified his fender to use a 170 tyre.
Old 03-12-2012 | 10:15 AM
Lakerat's Avatar
Lakerat
The actual width of tires are brand dependent also. Actual width can vary by the load rating of the tire within a specific brand too, like Metz ME 880's for example. The best source I have found for info is on Dennis Kirk's site, they show spec's on just about every tire they sell.
Old 03-12-2012 | 10:31 AM
skootchnc's Avatar
skootchnc
it's less to do with your rim width.... and (as gr said) more to do with clearance of the swing arm, and belt.....140 is about as wide as you can go, I believe, but you may have to trim the belt guard.
Old 03-12-2012 | 11:13 AM
Recycled's Avatar
Recycled
Maybe more than you would want to take on but because you have an '07, it is relatively easy and inexpensive to get a 180mm tire mounted on your bike. It was a winter project for me that I am just finishing up. Just need to fit the new fender. To see how...click the link below.
https://www.hdforums.com/forum/touri...-a-how-to.html
Old 03-12-2012 | 11:14 AM
Hogpro's Avatar
Hogpro
Former Sponsor
150 is the widest you can do.
Old 03-12-2012 | 11:41 AM
Holzarbeiter's Avatar
Holzarbeiter
The E3 in 160/80 fit on my 07 FLHTPI just fine. The Avon Venom in 150 was wider than the E3 I think this has to do with the shoulder design
AGAF
09-18-2016 07:24 AM
archangel74
04-29-2012 02:25 PM
jcbikn
Wheels/Tires
12-04-2011 01:08 AM
itsstock
09-21-2007 09:55 AM
Ghost_FL
10-17-2006 05:54 PM
Quick Reply: Another Tire Question?
