Air temperature gauge?
harrell42, i installed a harley otg om my 2011 limited where the atg goes. it was near useless until i found a nut that the sending unit probe would srick out from the nut about quarter of inch, the original probe did not stick out any and would not read good and took a long time one that stuck out about a inch would work much better. mine now reads about 15 degrees lower than the oil temp dipstick i have also. dont know which one is correct. roller
I work on cars and bikes.
I am in the habit of glancing at the gauges once in a while.
oil pressure is crucial...and a lower than normal OP reading under hot conditions gives an indication of oil thinning out due to high heat.
But I really doubt that's I'd spend time staring at an oil temp gauge in the dash.
I do have the dipstick with led readout which give s a "pretty good" display of oil level and a very accurate oil temp.
I can reach down hit the button and glance at it at a stop or while riding it I am concerned
mike
mike
