Front Brake pads
Front Brake pads
I just had my all my brake pads replaced at the dealership. When I had my new tires put on, Now the front pads sound like they are rubbing the rotor And making a noise a lot louder than Before I had them put on.
sound goes away when i aply the front brakes . Will they wear in so they don't rub or should I bring it back in? can they be adjusted?
Thanks for any info
2007 ultra
Thanks for any info
2007 ultra
Brake noise
I would pull the front wheel back off and reinstall it per the manual.
I had the same issue once and that corrected the problem.
They didn't score before, they score now. Wheel is not in the same place, thus the rotors are not in the same place. Check to see if wheel spacers are correctly installed. I'd take it back and make THEM fix it. Of course you can probably fix it yourself, but they caused the problem, not the brake pads.
I would take it back and have them check it out or if you have a lift check to see if there is any undo drag as you spin the wheel.
It would be my hope that a dealer would service the calipers with any brake pad replacement but I am not sure that they do. This would reduce the chance that the pistons are not retracting properly. I do it every 5k or so.
