Throttle grip - doesnt seem right to me
Location: Western Illinois, land of bad roads, and corrupt politicians
2 torx on the brake, 2 torx on the switch housing. Loosen just enough to slide the assembly towards the center. Tighten the torx. You're done.
Throw a bath towel doubled up on the tank, in case you drop something.
Is this on the 2012 RK? If so..... just drop by your dealer, and they will probably do it for you. Only takes a couple minutes.
