Correct Size 2011 Street Glide Front Tire (Mistake in Owners Manual?)?
Old 09-25-2012, 11:11 PM
Wv7o's Avatar
Wv7o
Wv7o is offline
Originally Posted by Icetek
Hi, I know its a slightly older post but just picked up a pair of new OEM mag 2013 wheels to replace my 09 FLHX wheels that that are normal wire spokes. Wheels are shipping so I don't have them yet and was looking to get a new front tire - rear wheel is same size from my checks so should be OK. My 09 has a 17" front rim and the newer bikes come with an 18" rim which is what I bought.
After purchase I go to my favorite seller - J&P Cylces - and use their tire finder service. I have Metzeler ME880s now on my bike and wanted the same and they list the front Metzeler for the 18 inch wheel as 140/70-18 and not 130 as mentioned here is previous posts. I could never get my head around the metric sizes so does Metzeler do something different resulting in the different size??
Am I good to go with the Metzeler 140/70-18??
Thanks
Mike
J&P lists the Metzeler ME880's in the 130/70B18 front tire
http://www.jpcycles.com/product/216-012
and the Metzeler ME880 in the 180/65B16 rear tire
http://www.jpcycles.com/product/216-151
Old 09-26-2012, 12:14 AM
INZANE's Avatar
INZANE
INZANE is offline
Thanks
Mike
Yes, running the pirelli night dragons in the same size... good to go. The 130 size mentioned above is also good...I prefer the larger tire.
Old 09-26-2012, 03:55 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
Talking
Mike,
The US Government passed a Law in 1975 to go metric, they just didn't say when! Are you saying you are not being educated in the metric system?!
Sorry, couldn't help it. Converter here. Tyres have been metric in part for around 40 years, meaning the stupid things have inch diameters and metric widths.
Old 09-26-2012, 11:33 AM
Icetek's Avatar
Icetek
Icetek is offline
6th Gear
Originally Posted by grbrown
Mike,
What I remember about 1975 (I was 9) was waiting in long gas lines on the days we were allowed (something with license plate numbers I think on which days we could go - this was in NJ) with my father and him bitchin about the the long lines and how the government wanted us to go to the 'stupid' metric system. It wasn't until I starting working in Italy that I got my head around metric volumes and distances... which make sense with the 10/100 rule!!! How many meters in 6 kilometers vs how many yards in 5 miles... Gee both are so easy!!!
But this...:
Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91S
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm / 25.4 = 8.86"
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
Even with all that I could not tell you it was a 31' tire diameter (or whatever it adds all up to)!!!
Just sayin...
Old 09-26-2012, 12:19 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,349 Likes on 5,493 Posts
Old post but may as well put the right sizes up for the next person.
Look at the correct line
ALL MODELS EXCEPT FLHRC FRONT 17 inch D408F 130/80B17 65H
FLFRC Front 16 inch D408F 130/90B16 67H
FLTRX, FLHX Front 18 inch D408F 13070B18 63H
ALL MODELS Rear 16 inch D407 180/65B16
Page 23 2011 owners manual
Old 09-26-2012, 12:29 PM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Mike, it's only arithmetic. Helps to keep the old grey cells active.........
Old 09-26-2012, 12:49 PM
Icetek's Avatar
Icetek
Icetek is offline
6th Gear
http://www.jpcycles.com/product/216-150
Wv7o, my fairly new rear tire is the same as what you linked so I should be good there. But I checked HD's page and they list the 2013's with 130/70B18 and you linked 130/80B17 on J&Ps site (which I am running on my OEM 17" wheel on my 09 FLHX now).
J&P lists the 140/70B18 (http://www.jpcycles.com/product/216-145) as the tire for the 18" wheel which I just bought that came from a 2013 FLHX.
Doing the math from online (and if I am doing the metric conversion right??):
130/80B17
The 80 indicates that this tire size's sidewall height (from rim to tread) is 80% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 130mm and that its section height is 80% of 130mm. By converting the 130mm to inches (130 / 25.4 = 5.12") and multiplying it by 80% (.80) we confirm that this tire size results in a tire section height of 4.1".
So an 18 inch wheel with this tire will result in a (17+(2*4.1)) 25.2 inches diamter.
For the 140/70B18
140/25.4 * .70= 3.85
So an 18 inch wheel with this tire will result in a (18+(2*3.85)) 25.70 inches
So the difference in tire diameter between the tires is 0.5"
Again if I am doing this correctly the 140/70B18 tire is just over 1/2" larger in diameter than the 130/80B18. Will I have no issues with rubbing or anything with this larger diameter tire?? I've read that you can almost fit a 21" wheel on a stock FLHX but might need to lift the fender about 1/8 inch to avoid rubbing at speed as the tire expands. But not sure what tire they are running on a 21" wheel.
(See grbrown I can do metric (I think)... I just need access to Google!!! But now my head hurts!!! LOL)
And just because I have never ever posted a 'Smiles' and my kitten has been chewing on my leg while writing this:
So I can cross 'Posting a Smiles" off my bucket list!!!
Old 09-27-2012, 11:54 PM
Wv7o's Avatar
Wv7o
Wv7o is offline
Icetek, id did post the wrong link I corrected the front fire link in my earlier post.
For those that may need it i have posted it hear also.
Jose Dominguez
04-03-2016 09:27 PM
m0v1em4n
06-15-2015 03:10 AM
Paul322
10-30-2012 12:05 PM
Mike Willmont
04-29-2012 07:52 AM
tony wiley
07-07-2011 07:27 PM
Quick Reply: Correct Size 2011 Street Glide Front Tire (Mistake in Owners Manual?)?
