which vacuum pump for beeding brakes
Old 03-05-2012 | 09:58 AM
c50plus's Avatar
c50plus
Default which vacuum pump for beeding brakes
Want to change my brake fluid and want to use the vacuum method.
Which brand would you recommend that is not too expensive?
I am not a mechanic so do not want to spend too much $$$ since I do not do this often. Thanks
Old 03-05-2012 | 10:14 AM
Uncle Larry's Avatar
Uncle Larry
The "Mighty Vac" is a useful and versatile set up .... and I believe that it comes in a couple of different configurations ...plastic assy .. metal also. Here's a link to Harbor Freight
http://www.harborfreight.com/catalog...?q=vacuum+pump
Old 03-05-2012 | 10:27 AM
DanDman's Avatar
DanDman
I have the Harbor Freight branded one. Got it on sale for $24, it's worked fine. I had a Craftsman pump and the HF looks the same.
Old 03-05-2012 | 11:10 AM
scottmotorsports's Avatar
scottmotorsports
I have this one and have used it for brakes on the bike and also for oil changes on the car. Great all around tool with great capacity
http://www.farmandfleet.com/products...c#.T1TlSFE7-0s
Old 03-05-2012 | 01:06 PM
Uncle Larry
Well, Whadda ya know .... Here's your sign! ( Link )
https://www.hdforums.com/forum/touri...ighty-vac.html
Old 03-05-2012 | 01:20 PM
Eric in chicago's Avatar
Eric in chicago
too late, snatched that one up 10 mins ago.
I used to use the motive pressure bleeder on my cars and tried to adapt it to the HD but did not have any luck. the MV is the way to go (or one of its clones)
Old 03-05-2012 | 01:47 PM
2009blackpearle's Avatar
2009blackpearle
Default Year?
What year is this bike. If it has abs u need the digital technician device to get the abs modual to let the fluid bleed
Old 03-05-2012 | 04:06 PM
dibe's Avatar
dibe
If you have a compressor I would recommend http://www.harborfreight.com/brake-f...der-92924.html
I have one and it works quite well.
Old 03-05-2012 | 05:49 PM
rlaf75's Avatar
rlaf75
I use one from the matco tool truck. I didnt buy it specifically for the scoot. I use it at work.
Old 03-05-2012 | 08:01 PM
EG-2006's Avatar
EG-2006
I also use the Mighty Vac and it works great. Non ABS 06 EG.
Quick Reply: which vacuum pump for beeding brakes
