WHat should I use to touch up this chip?
I'd try a little "wrinkle black" applied with a q tip or brush.
it usually comes in a spray can, just spray some in a small plastic tub like cottage cheese comes in, dab the liquid in the area.
do your best to get the area dirt/oil free.
pay attention to the directions regarding temperature
mike
mike
mike
mike
That powder coat looks a little thicker that standard paint prabably due to texture. On my custome I did the following to repair powder coat. ''
GO TO TRU-VALU AND GET A SMALL CAN OF BLACK STOVE HIGH HEAT PAINT. YOU WONT USE MUCH BUT THIS WILL HELP GIVE YOU A MATCH.
USING A FOAM SMALL PAINT BRUSH APPLY A COAT TO THE AFFECTED AREA.
REPEAT UNTIL COVERAGE IS EVEN AND DARK. ALLOW TO SET AND DRY 3 HOURS.
ONCE DRY GET A CAN OF HD WRINKLE BLACK. THIS SHLOULD ALLOW YOU A FAIRLY CLOSE MATCH. BECAUSE OF THE TEXTURE OF THE HIGH HEAT PAINT ONCE IT DRYS , YOU SHOULD THEN MASK OFF AND PROTECT THE REST OF THE SURROUNDING AREA FROM OVER SPRAY.
SPRAY PAINT THE AFFECTED AREA WITH THE WRINKLE BLACK. YOU GET A MUCH MORE EVEN AND BLENDED LOOK WITH SPRAY VERSES TRYING TO BRUSH THE WRINKLE ON.
BE SURE TO ALLOW IT TO DRY OVER NIGHT IN A HEATED AREA.
DONE. THIS WORKED WELL ON MINE. GOOD LUCK...THAT CHIP ON MINE DROVE ME NUT, SO I HOPE THIS WORKS FOR YOU OR AT LEAST HELPS.
Received 74,866 Likes
I use black BBQ pit high heat paint to touchup the area. I might change next time to that black bed liner paint for p/u.
