Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?
Old 03-04-2012, 04:25 PM
Niblet's Avatar
Niblet
Niblet is offline
Default Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?
any ideas? over the starter? I assume I reuse the stock hardware?
why didnt they give me longer bolts? anyone install this bracket before??
it looks like it may cause interference issues with the ignition lead??
Attached Thumbnails Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?-img_0054.jpg   Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?-img_0053a.jpg   Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?-img_0055.jpg
Old 03-04-2012, 04:28 PM
Niblet's Avatar
Niblet
Niblet is offline
the L tab bracket attaches to it supposedly
Attached Thumbnails Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?-img_0056.jpg
Old 03-04-2012, 04:29 PM
Niblet's Avatar
Niblet
Niblet is offline
Not much to go on here,,look at these crap instructions
Attached Thumbnails Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?-img_0057.jpg
Old 03-04-2012, 04:42 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,249 Likes on 1,640 Posts
Looks like you got it correct...bracket mounts on starter/top tab to rear & eyelet from pipe/clamp bolts to top. Funy how these vendors who deal with their products daily never test their instructions on riders for quality/clarity. Your guide pretty much looks like most I've seen - cryptic at best...good luck & post some pics when you get them 100%.
Old 03-04-2012, 04:49 PM
Eric Moore's Avatar
Eric Moore
Eric Moore is offline
yes that bracket supports the back head pipe that bolts to the starter mounts.. I see your bracket has a slot in it mine had a hole..round.. it caused my head pipe to be to close the the side cover & burnt a spot on the cover..I contacted bub about this... I told them I had to make a slot or ovel in the bracket to allow enough clearance... I see someone changed it..
Old 03-04-2012, 05:14 PM
Niblet's Avatar
Niblet
Niblet is offline
Eric
thanks for the help,,I like your bike,,what color is that? a harley color???
so it is ok to reuse the stock starter bolts?? the bracket is quite thick,,will this be an issue??
Old 03-04-2012, 05:23 PM
Eric Moore's Avatar
Eric Moore
thanks & yes stock 09 color...i think its dark blur pearl.... here is a theread of another true dual issue... watch your clerance...
I didnt have any issues with the bolt length... should be fine..there was alot of thread engagement
https://www.hdforums.com/forum/touri...b-headers.html
Old 03-04-2012, 05:30 PM
Eric Moore's Avatar
Eric Moore
your going to notice the plug wires on the coil come real close to your pipes.. thay may not burn but I installed a set of these to my wires for protection..i got them in black...
http://www.summitracing.com/parts/THE-14350/
this may have been the brand i used..
http://www.summitracing.com/parts/TAY-2559/
Old 03-04-2012, 05:42 PM
Northbound Southerner's Avatar
Northbound Southerner is offline
Originally Posted by Niblet
Eric
I just did this last week. Great pipes but the instructions SUCK. Anyway, that bracket goes on the starter. The bolts are plenty long enough. Have fun. It was a PITA...
Old 03-04-2012, 05:48 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Another option for the plug wires are heat boots...we use them in race cars...Amazon sells them for $32 (set of 8). That's what I did & they work great.
http://www.amazon.com/Protect-Shield.../dp/B00178WH9G
Quick Reply: Help w/Rhinehart classic dual install on 2012 RKC- where does this bracket go?
