Antena question Detachabile tour pak
I did a detachabile tour pak on my 09 UC last winter everthing works great I finaley put the tour pak on last week for a day trip and noticed I had very poor radio reception. I check all my connections are good and realized the problems is with the antena coupler where antena is removed and coupler is installed and antena wire for tour pak is installed is there any help advise ... Joe
Make sure the tour pak has a good electrical ground- that metal plate under the mat is the ground plane, if it is grounded to the chassis, the antenna will work better.
other than that it's check and clean the connections.
I just leave a stubby in place for the am/fm/wb, the tour pak fits over it- pepboys $8.
I don't have cb so I can't help there.
Mike
Mike
kevin Z06 (01-12-2020)
09 Ultra Docking question
We are contemplating ordering the entire system: 54205-09 Docking hardware, 53246-09A Detach kit for Pak, and 70032-09 wiring harness. Since HD gives us loyal owners such "great pricing" for accessories, the whole thing will ONLY cost $790, not including installation.
While I'm trying to figure out which body part or family member to give them for these items would you address 2 questions: Is there a more reasonable place to buy these items. (tried Ebay).
Also, were you able to install everything yourself?
Thanks,
Mary Ann
flightsong@earthlink.net
Thanks,
Mary Ann
Thanks,
Mary Ann
Thanks,
Mary Ann
I found the comms plug relocation to be good but not happy with the antenna jumper leads. It's so easy to just unwrap the speaker and antenna leads from the side covers and just run them to/through the TP again, rather than use the jumpers.
One zip tie on each side after you re-run the wiring and your done.
You know you can check out the installation destructions at the HD website?
Good luck and happy to assist from afar if you go this way.
