engine light
Old 03-03-2012, 09:43 AM
Classic Rider's Avatar
Classic Rider
Classic Rider is offline
Default engine light
I have an 08 ultra classic, when I start it the engine light stays on for about 5 seconds after the bike starts. Can anyone give me an idea what might be happening, or what I need to check? This is the only time it comes on. Thanks in advance.
Old 03-03-2012, 10:01 AM
Dionicio's Avatar
Dionicio
Dionicio is offline
Sounds like You Have a history Code. To find out what it is, turn engine run switch to run Then push and hold the odometer reset button while turning on the ignition switch. Release reset button when diag appears. You then press the reset button on on each one of the letters that are displayed to find out what code You have. Let us Know what code.
Old 03-03-2012, 10:09 AM
BLACK 3's Avatar
BLACK 3
BLACK 3 is offline
I had the same thing on my 02' Ultra, nothing was wrong with it. One of the experts should have an answer
Old 03-03-2012, 10:13 AM
2black1s's Avatar
2black1s
2black1s is offline
Yep! It's telling you that you have a stored historic DTC.
Old 03-03-2012, 10:26 AM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
which light ? the wrench light or the oil light or what , maybe low fuel light
Old 03-03-2012, 12:59 PM
Classic Rider
Ok, Dionicio heres what came up dlR9, po131,151,577, 61006, no rsp
Old 03-03-2012, 01:57 PM
dawg's Avatar
dawg
dawg is offline
Received 3,232 Likes on 1,846 Posts
You actually saw the following:
"diag"
P0131= front 02 sensor low or running lean
P0151= rear 02 sensor low or running lean
P0577= cruise control input error
B1006= accessory line overvoltage
no rsp= no response
Old 03-03-2012, 01:58 PM
dawg's Avatar
dawg
dawg is offline
Do you have ABS? Is your cruise control working? Do you run any accessories hooked up?
Old 03-03-2012, 05:19 PM
Classic Rider
no abs, yes cruise is working, only accesory is a ipod plugged in. my ipod wire did have a break in wiring but i replaced wire with a new one. the light is not coming on now. i cleared the codes and no new ones came in. could the wire have been the problem. thanks DAWG
Old 03-03-2012, 05:33 PM
dawg's Avatar
dawg
dawg is offline
No ABS explains the no rsp, the P0131 and 151 are simply historic that at one time your 02 sensors sent a lean condition message, the cruise error can be explained as well so yes I would say the over voltage was probably something related to your ipod. If none of the codes come back, you should be all set.
Quick Reply: engine light
