Concerned About Oil Temp
I didn't have to deal with the cat in the exhaust pipe on my 09. I did add a oil cooler, synthetic oils, stage I with tuner and noticed a big difference. As stated earlier between break-in, lean epa tune, cat, stop-n-go riding, thinner cylinder - it's gonna get hot.
Received 74,565 Likes
I have the same 2012 in the same color and had the same issue with heat.
Remember, the cat is running temps well over 1000* - the parts (and your leg) around that cat will absorb the heat. And no, the factory oil cooler will not help unless there's enough air moving across it.
So, as suggested remove the cat and tune the bike.
Well, got to sign off - tornado sirens are blasting!
Good luck!
Good luck!
DK Custom
13
11-03-2013 11:13 PM
