tour pak amp versuses fairing amp????? reccomendations please
i have been researching the same thing, i came to the conclusion fairing amp is better because you dont lose any storage space which is very valuable for trips.
my 2 cents
my 2 cents
If you are considering the HD amps, IIRC there is a fitment exclusion for the in-fairing amp for your Ultra--probably due to the CB module mounted atop your HK radio--space is tight; of course, you can relocate the module to below the HK.
Unless you plan to make the Tour Pak detachable, I don't see much point in using the in-fairing amp--HD has been putting the amp under the tour pak on CVO Ultras since '06 w/o any issues.
Carl
Carl
VINNIE JAMES
06-04-2009 08:10 PM
