Can Of Dry Gas
Can Of Dry Gas
Anybody use dry gas regularly? My son (who doesn't ride) stopped at the house yesterday. We got talking about the ethynol at the gas pumps, and he suggested dry gas every 2nd or 3rd fillup. I'm not a mechanic. What does it do --- help get rid of moisture in the tank? Do you recommend it in the bike, if you've used it?
on a motorcycle you introduce atmosphere every time you open the gas cap and I dont think the alcohol in the dry gas will prevent moisture if the out side of the tank is colder than the inside. but the alcohol will make the engine, well feel like its running on alcohol so you may think "hey this stuff is great" hickup!!
anyway if you keep the tank filled it will keep moisture down in the gas tank just as well.
well thats just my opinion and according to the chemist and physicist here its usually wrong.
There is more power in ethanol than gasoline. When you run E85 in a car designed for it you can feel the difference in the fuel.
The big thing about ethanol is the fuel system has to be designed to run it. Ethanol will EAT a fuel systhem that does not have the proper seals and o-rings.
The second thing is because there is more power in ethanol your mileage will suffer. Cars actually have two different ratings. One for gas and one for E85. You can expect about 20 to 30 percent less mileage.
The third thing is I have not seen anywhere that the fuel system on our Harleys are designed for E85 let alone 100% ethanol. I beleive running either of these fuels by themselves would be a very bad thing.
thing.
thing.
It's very relative and your statement is misleading. A motor burning alcohol will make more power and burn more fuel doing it.
More power in ethanol? Um no. It is higher octane and you can add more timing to an engine designed to run up to e85 however there are less btu's per drop in alcohol so you have to burn more of it to go any given distance.
To set the record straight:
1 gallon of gasoline has 124,000 btu where
1 gallon of E85 has 84,400 btu.
So not only does the fuel system have to be designed correctly the ECM has to be able to sense the type of fuel in the tank and be able to make the changes to acheive the same power levels.
As a stock Harley sits it should make less power running E85.
