Harley Fairing Dash Pad Help
I purchased a used Harley fairing dash pad instead of a new one because I knew I was going to modify it. Well, I sent it out and paid to have it modified and when it came back and I went to install it, I discoverd that the screw hole in one of the blind nuts that hold it on to the inner fairing is stripped half way in. No....I did not strip it. It was already stripped apparently which is proably why I got it pretty cheap ... What would you guys use to repair this? I tried cleaning the first half of the threads with a tap to no avail. If I take the washer off I can get the short bolt to grab a little less than 1/4 of the deepest threads but I think it will ultimately just vibrate and pull loose, even with loctite on the bolt. The hole is too small for a heli coil and the nut is only being held in as you know, by the plastic backing of the pad. Suggestions? If I hadn't spent so much money modifying it, I'd toss it and start over.
Received 49,916 Likes
I know that you can buy a repair/replacement kit for the mounts that hold the outer fairing to the inner fairing .... if the mount on your dash pad is like the ones that are used on the inner fairing I believe that you can get them at the HD Shop. I think the part number is 16585-96 ... Check it out and see if this is what will help you. Good Luck Brother.
Hmmm, I'm thinking that since this is only torqued to 25 inch pounds filling the hole with JB Weld might be just the ticket? Or rather than opening a can of worms, maybe its just better to leave it as it is and see if it does ultimately vibrate apart or if the last 1/4 of the short threaded hole holds it together along with the loctite. I tugged on the pad pretty good and it didn't budge. I'd just hate to button it all up just to have to pull the outer fairing again on some road trip? Decisions decisions? Thats what Vermont winter boredom does to a soul!!
The bike is at home and I am at work. I also do not have access to high speed Internet at home...Yeah, in this day and age! Too rural. Maybe this will help a little?
http://www.harley-davidson.com/en_US...ts/-J03804.pdf
