My 2011 Ultra came with turn signals and running lights on the Tour Pak but not brake lights. I helped my brother installed the Harley harness on his 09 to give him all 3. Is that the only way I can go or have they came out with a harness for the newer bikes?
As far as I know that's the only way to go. I've installed it and also have converted my turn signals to run/brake/signal. Maybe there's a way that you can simply not hookup the turn signal wires from the harness to your tour pak lights.
Did you buy the bike new? I ask because from MOCO, the tour pak lights are run/brake, but not turn signals.
Another option is custom dynamics I installed their set up,it is truly plug and play.Talk to Chis he'll help you with anything your trying to do.919-488-0125
