If there factory grips your best bet is to get new ones. Most people end up cutting the left grip off because its glued to the bar & is very hard to remove without damage.
It's a 2011. The left grip will come right off, just twist it a little. Those are non-adhesive grips so don't use any when you put it back on either. There is a notch in the switch housing which holds them on & prevents rotation-much easier to work with than the old glue type.
You sure about that, mine started spinning on me right from the dealership. Ended up going with an upgrade and that one didn't need any adhesive. It feels like it wants to spin sometimes but I figured it might need some goop in the future.
