Question on Custom Auxiliary Lighting 69227-04A
Read through all the discussions I could find on this kit. I think I have most of the parts to do this without buying the kit, except for the brackets, which aren't sold separately. From those who have this setup installed, what is the difference in the lamp housing in the kit and the ones on the stock light bar? can the stock ones be used in place of the aux housings in the kit? You have to reuse the lens/bulb assemblies from stock, so curious what's the diff in the housings. I also have stand-offs for the bullet TS left over from putting the red lens conversion kit on my Deuce back when, and the bullet TS off a FLHX. I have the butt splices, nuts, washers, etc that I didn't use from the bullet TS kit that mounts up to the stock light bar. So, it looks like all I would need is the L/R brackets themselves and some miscellaneous hardware (inexpensive). Saw a set of brackets on Craigslist for $140, but didn't think that was such a good deal. Comments? Anyone got a set of brackets for sale? Thanks in advance.
Auxiliary Lighting
If anyone is interested, I did find out that the OEM towel bar passing lamp housings have a different P/N than the auxiliary lighting kit:
Stock housing 72160-06
Kit housing 68822-04
Our local dealer has a kit on the wall so I'm going to see if they will pull one out and compare it to a towel bar light.
Anyone have a set of the brackets lying around collecting dust?
jerryw618
05-18-2010 09:20 AM
