Detachable TP Parts
Detachable TP Parts
I have done a little research on HD website for part numbers but as usual, it is a little confusing. If I were going to set add the quick detach hardware for my 2011 Ultra, what parts what I need? I see on HD's web site, I would need P/N 53246-09A but also P/N 70032-09 for the wiring harness. Don't I have to relocate the license plate and antennae? Any help is appreciated....
Quick Detach Hardware
Detachable Tour-Pak Rack for Electra Glide - '09-Later Models
Transform your Electra Glide model for around town cruising. This kit includes everything needed to convert the rigid-mount Tour-Pak to an easy on-and-off detachable version. Complete kit includes two-up docking hardware kit, Detachable Two-Up Tour-Pak Rack, chrome strut covers, chrome license plate holder, reflector, and AM/FM antenna relocation hardware.
53246-09A
Fits '09-later FLHTC, FLHTCU, FLHTK and FLTRU models. FLHTCU and FLHTK require separate purchase of Wiring Harness P/N 70032-09. FLTRU models require separate purchase of Wiring Harness P/N 69200181.
MSRP US $549.95
What he didn't point out was that the kit contains, among other things, the new bracket to reolcate the tag, and the correct strut covers (extra holes for the docking hardware. Didn't turn out to be a big issue for me because I put the bullet TS bar from FLHX on rear with a curved tag holder underneath and bought gloss black strut covers (instead of chrome) to work w/docking hdwe. I don't have the extra lights and put a hidden antenna inside the fairing, so I just capped and stowed my antenna wire in the starboard side cover. I've seen other posts where members have made their own harnesses.
So, long story short, if you get the kit above and the extra wiring harness for your application you won't need ANYTHING else. If you piece it together like I did, that's another story. Just depends if you've got the $$ for the big kit!
The kit that HD sells includes tag relocation hardware but I am unsure about their solution for the antenna.
Personally, I did not like the way the tag relocation looked and did mine piece meal.
I didn't want the hassle of messing with the antenna when I pulled the tour pack so I bought J&M in fairing antennas. I also moved my tag below the tail light with Custom Dynamics LED smoked lens setup.
If you're interested I'll try and get a pic of the rear end (the bike's not mine) and show you what it looks like.
I love the way it cleaned up the rear of my UC.
HTH
-Carl
HTH
-Carl
HTH
-Carl
HTH
-Carl
Crappy pic but you get the idea. All smoked lenses with LEDs. License plate below tail light with LED frame. Badlands run/turn/brake module. Most of the time I ride solo and short trips (<100 miles) so I use the Badlander seat. If I take a longer trip I use the modified stock seat and sissy bar. If the OL rides I use the stock seat and tour pack.
been a while...but help please, lol
