Ordered Custom Dynamics Set-up today
Old 03-12-2012 | 07:12 AM
brettnbama's Avatar
brettnbama
rear should be 1157s on SGs or RGs with no center tail light.
Old 03-12-2012 | 11:16 AM
SoCalMike's Avatar
SoCalMike
Originally Posted by JayRossi
did you order the 1157s or the 1156s for the rear?
I ordered kit GEN200AW-KIT-1157, so if you were looking just for the rear brake/turn signals it would be the 1157's.
Old 03-12-2012 | 01:11 PM
CHILLLS's Avatar
CHILLLS
this is SWEET same color bike too
iv been wanting to do this too, looks FANTASTIC.
can you post up the P/N of the strobe for braking?
i think you taking pics of the lights in the direct sun is awesome because that will be the worst case scenario of being able to see or not see the lights. who cares about taking a pic at night...there LEDs of course there going to be bright as #*%!. so thank you for your pics, very well done in my opinion.
you will be ridding safer now & some day i will to.
you have made my decision on getting these LEDs for mine.
thank you again CHILLLS
Old 03-12-2012 | 02:14 PM
SoCalMike's Avatar
SoCalMike
Here's the part for the "Magic Strobe" to fit a '10-'12 FLHX: MAGIC-STROBES-SS6
After I installed the new rear lights my buddy made a comment. He said before I installed the new lights they tended to 'blend into your bike' given the color. He said now (new CD LED's/Tri-Bar Upgrade) there is no mistake about your running/brake lights. He is a rather 'thrifty' individual, and said they were definately a worthy investment. That settled and validated it for me. Thanks for your kind words. I'm working on it and have along way to go, but I'd like to be as through and informative as some of the real experts here on this forum.
Old 03-12-2012 | 02:50 PM
CHILLLS's Avatar
CHILLLS
thank you & THANK YOU.
Old 03-12-2012 | 03:06 PM
CHILLLS's Avatar
CHILLLS
one more thing, did you have to run a load equalizer for the front & rear or is one equalizer enough to cover front & rear??
Old 03-12-2012 | 03:12 PM
Garemlin's Avatar
Garemlin
In most cases one load equalizer will be good for your front and rears. Depends on what make you use. I use Biketronics Smart Equalizer which covers the whole bike.
Old 03-12-2012 | 03:36 PM
Nute's Avatar
Nute
I installed the CD equalizer with the RF supression. Very easy straight forward install and works great and didn't take up much room under the seat. No issues whatsover.
Old 03-12-2012 | 05:21 PM
SoCalMike's Avatar
SoCalMike
Right, one equalizer does the trick. If you don't add one your turn signals will think a bulb is out and they will blink very fast. If you have a security system on your bike, for whatever reason, it will cause a condition such that the red 'key' will lite up and remain lit. I know this a) because it's fairly well documented in the forums, and b) I intitally installed one front and one rear light in order to get some side by side comparisons for a few days and proved all the experts correct!
To reiterate, the CD Load Equalizer is fairly big so I mounted it under the seat in the battery box and ran the wires out through the fuse mounting block. The CD Load Equalizer also needs power to operate whereas the Biketronics unit does not, so you have to install additional lugs on the battery. Personally, I would opt for the Biketronics (for space/simplicity) if I needed to replace the CD unit for any reason. My setup seems to work well with correct turn signal blinking and my security 'key' does not remain lit any longer.
Old 03-12-2012 | 11:28 PM
CHILLLS's Avatar
CHILLLS
Talking Yeahh buddy!!
just placed my order with biketronics & custom dynamics.
also got the strobe from CD on your recommendation
now the part i dont handle well...THE WAIT!
i thank you (my wife wont) socalmike for the pics today that helped with my decision on these lights.
i think we will just keep this between us cause if the wife finds out im blaming YOU
