Lyndall Z-Plus pads installed today
Bought three pair of Lyndall Z-Plus brake pads from a seller on Ebay. Installed them on the 2010 Ultra today. Went for a 70 mile spin. Really like the feel. No noise or squeal. Straight-forward install.
The original pads still had thousands of miles of use remaining, but my goal was to rid myself of some if not all of the dust created by the stock pads. Guess we will see how that goes.
I paid $125 shipped for the three pair set.
Tools I utilized for the job:
-inch pound torque wrench
-foot pound torque wrench
-5mm Allen socket (for the brake pad pin bolt)
-10mm 12 point socket (for the front caliper mounting bolts)
-5/16th Allen socket (for the rear caliper mounting bolts)
-Socket drivers and extensions
-Needle nose pliers (to pull the pad bolt pin)
-Black tie wraps (to replace those cut during the operation)
-Pocket knife to pry off caliper screen
-Brake and caliper lub
-Silver anti-seize
-Spray brake cleaner
References:
-Service manual
-Parts manual
-.pdf from Howard at Motorcycle Metal
Thanks to everyone that posted about the Lyndall pads. Your information helped me make the decision to go with the Z-Plus version of the pads.
-Silver anti-seize
References:
-Service manual
-Parts manual
I had issues on my 04 Ultra with the z-plus pads but it was the old style brakes. The pads did not want to stop me when wet (rain). E-mailed Lyndall and they sent me the gold pads and had me return the z-plus pads and had much better results with the golds. Hopefull you'll have better luck with them on the newer brakes but be carefull till you know.
I had read where the Golds were more suited for wetter environments. But seems there were also issues with other stuff like dust, squeal, and such with the Golds in dry environments. You may not have any of those issues. I'll keep your comments in mind when I hit the rain. Thanks
I had them on a RK and they were excellent when they were wet, didn’t squeal and almost no dust. I put them on my SG and they squealed after a few thousand miles. I called and they sent me a full set without even asking me to return the originals. The they sent me 7254 Z-Plus and they had three slots cut into them and they have been fine in all respects.
If yours had the slots I would guess you have the improved version. If not and you have a problem I suggest you let them know. They seem to be a company that is concerned that their products that are out there are performing well and are anxious to make it right if they are not.
The owner called me a couple of weeks later to be sure I was satisfied and apologized for the problem.
