SS 583 EZ Start or Andrew 21 or 26 Cams?
I am debating which cam to get for my bike. Anyone with pros and cons with the two? Which is better and why? S&S or Andrews?
Cam upgrade is for a 2009 Street Glide with SE Racing Tuner, Stage 1 download, PM High Flow, 13K, V/H PowerDuals. Thunderheader tips, and V/H Throttlepak.
Which sounds and performs better?
Thank you!
Thank you!
Can't say anything for performance but the S&S Easy Starts will save your starter especially if you plan on adding compression later on. I just did a 107 build with the 551 Easy Start cams & didn't have to add compression releases. I'm now at 10.1 compression ratio & the bike turns over just as easy as stock.
You really don't say anything about your riding style, what bike you have, how heavy you or the combined passenger load is, so its hard to say which is better.
Based upon my experience on one cam. Plus I have a totally different motor than you have, AND I have not intention of future motor upgrades. I can not say enough about how much I like the Andrews 21 for everyday riding. Tons of power where I want it. Lower in the RPM range. There is my $0.02.
You signature inidicates that you are running a SERT and a V/H ThrottelPak; what's a ThrottlePak? Sounds like a tuner but so is the SERT.
