How do you line up bags
Yes sir, Those are the Top Shop fender overlay and Bags. The bags came perfect. OEM lids. The overlay..Ehh needed some skimming and a lil work to make it right. Body Shop guy said what a lot of people said on site about them. They are garbage and wouldn't recommend them. he did say after it looked awesome. But my take on it was, From a body guys stand point he didn't like them.
It will probably be posted again in a month when I get it home. if I cant get it to where I want it. Right now its about 70 miles from my home. So new pictures are not easy. But any help would be appreciated
Have to watch that you don't get the top too close. The rear latches can rub the fender from vibration if there isn't enough clearance. May shim the front top mount out to bring the rear a little closer. I had to open up the rail mounting holes in the lower rear to move the rails out to get the bottom of my bags to set right. Had to do a little grinding on the lower rubber mounts as well. But I only paid $300 for the bags and fender so I expected some adjustments would be necessary and fitted everything before paint.
As for the bags and fender I would think no matter how pricey they are. You have to make some adjustments for fitting
But thx for help
Aroberts
10-02-2007 06:58 PM
