Notices
Just ordered the TCB braking System
Old 04-22-2013, 08:22 PM
TexFF's Avatar
TexFF
TexFF is offline
Any more input from users, good or bad?
  #32
Old 04-23-2013, 08:13 AM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
A buddy had it on one of his Harley's and said it worked great. Its on my list.
  #33
Old 04-23-2013, 08:36 AM
Pondskipper's Avatar
Pondskipper
Pondskipper is offline
It is basically a pressure relief valve for your brakes, a lot simpler than ABS and probably a bit better.
  #34
Old 04-23-2013, 05:33 PM
J_ULTRA's Avatar
J_ULTRA
J_ULTRA is offline
Originally Posted by FL-kruzen
For us without ABS brakes, I ordered the TCB Braking system
http://www.tcbbrakesystems.com/). I was riding and during a light rain some *** hole pulled out in front of me and when braking by back wheel locked up and I was able to maneuver around the vehicle without wrecking my bike! With soiled underwear I decided to do something about this. I did allot of research and found that the TCB Braking System is the ticket for safer panic braking.
I'm going to give serious consideration to this setup. Twice on my Springer I locked up the brakes in a panic situation (freeway speeds) due to traffic accidents three or four vehicles ahead of me. Both times I instinctively immediately released the brakes to stop the skid, simultaneously checking the rearview mirror ito check the next lane and luckily the lane was clear both times. All this was a reflex action, there was no time to think. This Ultra is so big and heavy I wouldn't want to go through an uncontrolled skid (as brief as they were) again. I'm thinking these little devices would help prevent that and maintain control. I used to do some dirt track way back in the last century and could generally control a skid, but not with this behemoth.
  #35
Old 04-23-2013, 06:14 PM
taconite's Avatar
taconite
taconite is offline
I just put one on my rear brake, but the weather is not letting me out to try it. The pedal feels like it has a lot more "squish" to it, witch is what I wanted. Time will tell but it seems like a great idea. My rear brake was very sensitive to lock up. Anything other than a gentile push and the tire would skid,. I'm hoping this dampens that issue!
  #36
Old 04-24-2013, 08:19 PM
mikelikesbikes
I would be most curious how this works out for you. Since installing Lyndall pads I have locked the rear too many times.
  #37
Old 04-24-2013, 08:33 PM
HeyYou's Avatar
HeyYou
HeyYou is offline
Remember, these only work to absorb spikes in pressure aka panic stop. Hit some sand or ice and they won't do a damn thing, whereas ABS works like a charm. I tried my ABS recently on some sand and the action was smooth and easy.
Would I put these on a non-ABS bike? Probably. But these are situational at best.
  #38
Old 06-03-2013, 08:57 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
After having my RKC sideways, in traffic in DFW while executing a panic stop due to an idiot in the middle lane braking from highway speed of about 65 m.p.h. to near 30 m.p.h. to try and cut across three lanes of traffic to the exit. After this incident, I resolved to find something to assist with the rear brakes on this bike. I have ridden various types of bikes from sport racers to dirt bikes for over 40 years and I attribute my ability to recover the machine to the skills that I learned and practiced but I think it would be foolish to depend on that every time.
Nevertheless, the rear brakes on this bike lock up in situations that are inconvenient to say the least. During my panic stop I could see the left side saddle bag in my peripheral vision and it should never have gotten that far. I remember a conscious thought to not hammer the front brake and I was able to modulate it and get the bike slowed down enough to let up on the rear brake to get the bike straightened out. That was not any fun and I am going to give the TCB a try on the rear. Hopefully it will absorb the first jolt of pressure from a sudden stop situation and keep the rear wheel from locking and becoming a major problem. I have always been a dual brake user and have often used brakes to make a bike I am on do certain things but I like to KNOW what it is going to do, not surprise me like an Amway salesman.
I understand what the TCB is supposed to do and that is to allow the rider to DECREASE stopping distance by preventing the wheel from locking up. Theoretically it does this by keeping the wheel rolling and allowing the brakes to be applied instead of locking up and skidding uselessly in a panic stop situation.
I am going to go down to the high school parking lot and measure some stopping distances prior to installing the TCB and then after to see if it really has a positive affect on the braking distances. I have an open mind about this and see the wisdom in it, hopefully it will work as advertised. Either way I will report my experience here.
  #39
Old 06-04-2013, 12:00 PM
mikelikesbikes
I will be curious of your before and after findings. I have the TCB in hand which will be installed next week when I have the rear end of the bike torn down replacing the swingarm.
  #40
Old 06-04-2013, 03:57 PM
ClutchFan22's Avatar
ClutchFan22
ClutchFan22 is offline
I put one on the rear only of my 07 SG after having issues with the rear wanting to lock up easily. So far it seems to work ok, though as others have said if you want to, you can still lock it up. In my experience with it only on the rear brakes, it seems to provide a decent buffer to keep the brake from wanting to lock up easily and still providing sufficient stopping power. With that said, I am also not convinced I just do not pay more attention to my braking habits since I installed it, which also might help. I have and always do use both sets of brakes when braking, but this item does seemed to have helped my lock up problems I was experiencing frequently with the rear of the SG.
Quick Reply: Just ordered the TCB braking System
