Check Engine light
Old 02-24-2012, 08:16 PM
Swftsildedly's Avatar
Swftsildedly
Swftsildedly is offline
5th Gear
Default Check Engine light
2012 electra glide classic,,,check engine light and low battery light come on and voltage drops to 12 volts,,,when the lights go out the volt meter shoots up to 14 and the lights go off. The volt meter slowly drops again to 12 and the lights come back on again,,this is all happens while the bike is moving. Any help would be appreciated.
Old 02-24-2012, 08:20 PM
FLTRU4ME's Avatar
FLTRU4ME
FLTRU4ME is offline
Check the battery connections. Had that happen on my 2010 once. But it might be a bad battery.
Old 02-24-2012, 08:52 PM
TSD's Avatar
TSD
TSD is offline
By brothers bike had the same exact problem.After we checked all the connections and replaced the battery, we still had the same problem. Turned out to be the voltage regulator. His bike is an 06 FLHTC.
Old 02-24-2012, 09:00 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
voltage reg is my guess but check the easy stuff first.
Old 02-24-2012, 09:17 PM
Swftsildedly
5th Gear
Thanks for the response, I checked the battery connections they are clean and tight.
Old 02-24-2012, 09:18 PM
Swftsildedly
5th Gear
Thanks for the reply, thats my guess to, the bike is under warranty so I will bring it to harley to replace the regulator
Old 02-24-2012, 09:19 PM
Swftsildedly
5th Gear
Thanks for you response it is appreciated
Old 02-24-2012, 09:20 PM
Swftsildedly
5th Gear
Just a shame I have to miss out on riding this weekend and next week to.
Old 02-24-2012, 09:37 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
I had the exact same thing happen to me, and when they check it first they replaced th regulator, 2 days later it did it again, ended up changing the stator.
Old 02-24-2012, 10:01 PM
Swftsildedly
5th Gear
Thank you, I will keep that in mind when I bring the bike in.
Quick Reply: Check Engine light
