Dunlop Elite 3 Bias Ply or Radial ?
#61
#62
The saga continues. My latest email to Dunlop and their response:
Hi Rob,
I received a replacement tire from J&P cycles over the weekend. Guess what, *it's a mislabeled tire also J&P cycles evidently has a bunch of the mislabeled tires. There is no way I am the only person that has received a mislabeled tire. I have now received two in a row.
*I have canceled my order with J& P cycles and will just wait for the replacement front tire that you are sending out. Dunlop needs to get with J& P cycles and get these mislabeled tires out of their warehouse before someone installs the wrong tire on their motorcycle.
Thanks,
Bob
Hi Bob,
Thank you - Yes, we are looking into the issue.
Your tire should arrive to you on Tuesday.
Thanks,
Rob
Dunlop seems concerned and helpful. J&P cycles, not so much. I won't buy tires from them again. Yes the mislabeling is not their fault but they show a complete disregard for trying to resolve the issues with their warehouse.
Hi Rob,
Thanks,
Bob
Hi Bob,
Thanks,
Rob
#63
#64
You have it absolutely correct - just installed the very same on my 05 Road King in December. Looking forward to trying them out - hopefully by the time Spring is official on March 20th.
#65
#66
I have a Dunlop Elite 3 radial on my FLHTK. The size on the rear is 180/70/16 and is about 1/2" taller than the stock tire. The 180/65/16 is a "Harley only" size created for the sole purpose of bleeding your wallet dry. Thanks MOCO, you unethical ******.
I bought it at a Honda dealer after a Harley dealer quoted me $450 to replace the rear tire. I figured a Goldwing is a big *** bike, why wouldn't one of their tires fit a Harley?
The tire I bought was originally destined to go on a Victory CrossRoads. It was pretty happy to end up going on my geezer glide. I saved a LOT of money too.
It works just fine. 6,000+ miles on it to date without issue. Oh, I have the OEM tire on the front still too. There was absolutely no noticeable difference in handling or performance. The only thing is that my speedometer is slightly more accurate now.
#67
It was a rear tire, that had a paper label on it that said it was a front tire. yes it could be used as a rear tire with no problem if it was the proper size for your bike. Dunlop sells this tire size as a front and a rear for certain bikes but the tires are different.
The Dunlop rep told me that after I brought it to their attention they checked their warehouse and found an entire pallet of mislabeled tires.
I am getting a replacement tire from JP Cycles and Dunlop is sending me another one as a thank you. so getting two tires for one.
I'll bet you dollars to donuts that I had a mislabeled tire.
Not that it matters to me now. I traded it in for a 2004 RG ;-)
#69
#70
crusteel45
02-18-2006 10:08 PM
