Will a battery tender fully charge a dead battery?
I just looked to see what a big crank battery was rated at, for a 88" dyna bike. It was 17.5 amp hours & 310 cca. I would think your battery would be rated somewhat similar. If that's the case (and it's any good), 8-9 hours at 2 amps should get you to 80%, and another 8-9 hours will get you the other 20%.
Here's a link to a site with some very interesting reading on lead acid battery maintenance. Maybe this will help you decide what to do?
http://batteryuniversity.com/learn/a...acid_batteries
If it were a deep cycle battery, designed to be substantially discharged and re-charged, you'd probably be ok. But your battery is designed for delivering high current (such as exerted during starting) and being immediately brought back to full charge. You may get it charged up. But unless you have AAA, or another service that will come get you (or bring you a new battery), I wouldn't rely on it. It's liable to just go 'dead' without warning. Even if you get it to hold a charge for a time.
The separate question about the Battery Tender, it's not the best bet for charging a 'dead' battery. The low rate of charge is, as others have said, designed to 'maintain' a fully-charged battery...higher current is generally required to restore a 'dead' battery. And as noted, a battery designed for starting a vehicle is not a good candidate for 'resurrection' once it's been fully discharged...especially if for a long (1.5 year) period of time.
Alan
Alan
Alan
Alan
thanks all for the battery edgumication
