Cardboard insert. abs
If you are moving the master cylinder, controls, grips, etc from one set of handlebars to another, you have to put the shim in there.
Wow...I don't think I would have looked at the manual to remove stuff from bars (cuz I never did before) without seeing this post. I would have never thought a shim would be needed...I never saw a directive like that before. Now ya got me looking at everything.... Didn't think a bar change was this involved.
Supposed to remove a fuse too....anyone NOT remove the maxi-fuse when doing bars? I would never have removed a fuse either but book says to....which means you take off a bag to get into side panel...WTF....I have to remove bags to change bars now....this is crazy I tell you.
I changed out my grips this past weekend. I had the cardboard shim in and put everything back together. I decided that I didn't like how it went back together so I took the master cylinder/braker lever off again without the cardboard shim. (I forgot). When I put it back together....yep broke the plastic tit off. However, my break light does not stay on and everything is working correctly. I have the BAL-1 taillight and turn-signals running/break ligths plug and play module.
