$18 led upgrade
I didn't do the speedo and tach, also I'm changing out the HK unit soon, so I didnt even worry about it. The LEDs I used were from Superbright LEDs but didn't cost $4 each, the number I see on the package is WLED-W-120 (194) wedge base, I'll see if I can't locate more info.
Steel, yeah saw those, they didnt have a natural white in that style. they are $4.95 a piece, a buck more. the WLED X5 are plenty bright, they have 5 individual led's. Marty the guy that does the speedo, tach and hk faceplate was referring many to the x5, I'd like to see a side by side comparison to see the difference.
I did the same upgrade to my 4 small guages. Used the superbrightleds WLED-xHP5 and used the red LED's. They are 10-20% brighter than the WLED-x5 and the Red matches the color of the radio faceplate. I originally installed the WLED-x5 but they were'nt as bright as I expected so installed the WLED-xHP5's instead. Here's what they look like. It's not as bright as the picture is making it out to be but way better than stock.
https://www.hdforums.com/forum/attac...s-dscn1007.jpg
