Barely made it home with primary banging like crazy!
Old 02-16-2012 | 05:08 PM
hover's Avatar
hover
Originally Posted by Rickr01
A broken tensioner or loose primary chain isn't going to cause the drive belt to suddenly hang low. Has to be something on the tranny end. I fear the worse on that one? Mainshaft bearing...
+1 on that
Old 02-16-2012 | 05:16 PM
soft 02's Avatar
soft 02
Originally Posted by hover
+1 on that
I hope not!!! PITA.
Old 02-16-2012 | 05:18 PM
Damascus's Avatar
Damascus
Default Thanks for the ideas, All
I'll start getting into it this weekend. Can't hurt to at least get it going and see if I can fix it myself.
I just called HOG Roadside Assistance and was happy to hear that I do not have to have it towed to a dealer only like I thought. There's a local indy with a good rep in case I'm out of my league.
The real bummer is that I just installed - and I mean just tightened the last bolt before my brief ride - a 17" Hogpro solid ala Fat Boy chrome front wheel on the bike.
So my bike looks great ... it just doesn't move. I start a new thread with photos of that Hogpro solid chrome front wheel when my spirits lift again.
Old 02-16-2012 | 05:34 PM
Ragtop's Avatar
Ragtop
From what you describe, I'm surprised you made it home if the belt is that loose!
Old 02-16-2012 | 06:06 PM
Damascus's Avatar
Damascus
Barely is the key word here. Thank God I was only a 1/2 mile away, and even then it was ...
clank! clank! clank! ... coast ... clank! clank! clank! ... coast ... clank! clank! clank! ... coast ...
I figured whatever damage was already done, and I just didn't want to call for a tow so close to home, or push that behemoth up even the small grades on the way.
Got plenty of attention from cagers, and probably a few laughs about Harley's always breaking down/should have bought a Honda/etc.
Oh, well. I got thick skin.
Old 02-16-2012 | 06:46 PM
BLKBAGGER's Avatar
BLKBAGGER
Are you sure your belt wasn't to loose and you stripped the teeth off of it?
Old 02-16-2012 | 06:50 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Got me thinking..You did check the rear pulley bolts ?
__________________
www.Captain-Itch.com
Old 02-16-2012 | 06:57 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
main shaft,but the rear pulley does sound awful too?if it didn't eat the swing arm its a easy fix.
Old 02-16-2012 | 07:49 PM
MarcV125's Avatar
MarcV125
and/or the rear axle nut backed off?.. just something to check?.. any work done to the rear wheel...you said new front wheel but just asking ...
Old 02-16-2012 | 08:23 PM
Ragtop's Avatar
Ragtop
broke pulley, or bolts, like others have said.
Quick Reply: Barely made it home with primary banging like crazy!
