nitrogen in tires?
nitrogen in tires?
just talked to a cousin who told me about a buddy of his who put nitrogen instead of O2 in his motorcycle tires. suppose to keep the
tires cooler on the pavement and allow you to run them a little longer before changeout. Have I missed something here?
anyone doing this out there?
twinfreeze
twinfreeze
RE: nitrogen in tires?
biggest advantage is the molecules are larger and more uniform which keeps the pressure more constant for less adding of "gas". you also get more load capacity, the tires stay drier inside for durablility and the cooler tire lasts longer. for $5 a tire it's cheap and refills/top offs are free.
The only advantage that comes with nitrogen is that it's DRY - no water vapor. Gases ALL expand and contract at the same rate as long as they are far removed from their boiling points - since water is close to its boiling point at room temperatures, it can expand and contract unpredictably. Nitrogen sold in bottles is quite dry which gives the illusion that it has some benefit. It's dirt cheap since it's free (78% of the air is already N2) and is a very nice way to screw a sucker into the hype. Save your money - it's BS at best.
