I hate it when this happens....
I finished up a Brembo front brake conversion on my 2007 FLHRS this weekend. As I was buttoning up, I noticed a small spring on my workbench that is about 3/8 inch long and about 1/4 inch wide. I checked my parts manual to see if it came out of my headlight assembly but I can't find that part listed. I don't have a parts manual that features the Brembo front master cylinder. I had a difficult time bleeding that sucker and am wondering if that small spring is supposed to be somewhere inside the MC. Does anyone have any ideas? I hate to have parts left over!
Received 49,857 Likes
Did you have your throttle apart? There's a little spring for the throttle lock, that one can get away if you're not careful.
I did the Brembo conversion on my bike a little over a year ago. Installed taller bars this winter and changed out the brake lines. Bleeding the brakes took about 15 minutes with a Mity-vac. Really good tool to have in your toolbox.
No, I didn't have the throttle apart, but it looks like that spring. I put speedbleeders on the calipers but it was the master cylinder that gave me fits. I found out later what bench bleeding means and that is what I should have done. After the MC started working it only took me a few minutes to bleed the system.
I am about to do this exact conversion on my 06. Please help me understand what you mean by bench bleeding.
AVilla
06-08-2010 10:19 AM
