Street Glide with Lower Fairings ????
Old 02-13-2012, 09:19 AM
JoeTag's Avatar
JoeTag
JoeTag is offline
I got the HD lowers because I liked the look of them on the SG and the protection. The fit is perfect and very easy to install. They helped with buffeting and I removed the chrome fork lowers. I have only had them for a couple of months but I doubt I will take them off in the summer.
  #42
Old 02-13-2012, 10:09 AM
sublime_ac's Avatar
sublime_ac
sublime_ac is offline
Originally Posted by CHILLLS
sublime....what size speakers are you running in the lowers?
did you use adapters or do you order the speaker pods the size you want?
6.5" using the Harley CVO speaker adapters.. There weren't any speakers installed yet in that pic..
  #43
Old 02-13-2012, 10:15 AM
Spartaman's Avatar
Spartaman
Spartaman is offline
are they HARLEY brand?
Yes they are. They only hit the turn signals after a 3/4 turn to either side. However, I can't turn them enough to lock the handle bars.
Any ideas? I tried adjusting the lower fairings more to inside and outside, but it made little difference.
  #44
Old 02-13-2012, 10:21 AM
CHILLLS's Avatar
CHILLLS
CHILLLS is offline
i only asked cause i have heard that some of the off brand lowers do this.
im just about ready to order my lowers & every time i read something about the turn signals hitting the lowers i second guess ordering them.
  #45
Old 02-13-2012, 10:57 AM
Dr. Tiki's Avatar
Dr. Tiki
Dr. Tiki is offline
mine clear with no issues... I'll grab that picture today as well.
  #46
Old 02-13-2012, 11:03 AM
Tripp_HPjunkie's Avatar
Tripp_HPjunkie
Tripp_HPjunkie is offline
same here mine clear........(fairing factory lowers) but my bike is a FLHT none lowered front end......so If you have a street glide with a lowered front end I could see maybe running into problems with them hitting........
  #47
Old 02-13-2012, 11:59 AM
JoeTag's Avatar
JoeTag
JoeTag is offline
Mine (the HD) have zero clearance issues. Plenty of room. Perhaps you need to double check the mounting.
  #48
Old 02-13-2012, 12:02 PM
HotRoc54's Avatar
HotRoc54
HotRoc54 is offline
I have my front lowered 1" with the HD spring kit.
Will I have an issue with turn signal clearence ???
It usually states in there products when a part cannot be used with another part or model. Nothing stated with ethier part.
  #49
Old 02-13-2012, 12:29 PM
saguache1's Avatar
saguache1
saguache1 is offline
I have the vented lowers and love them. Ready to look for speaker options. On ride to sturgis last year they worked fine not to hot and kept the grasshopers guts off my pants. I tried to attach a couple of pictures they are not great but show the lowers.
Attached Thumbnails Street Glide with Lower Fairings ????-imgp5828.jpg   Street Glide with Lower Fairings ????-imgp5842.jpg
  #50
Old 02-13-2012, 01:05 PM
sublime_ac's Avatar
sublime_ac
My front end has progressive mono tubes and is lowered 2"... No clearance issues at all.
Quick Reply: Street Glide with Lower Fairings ????
