Notices
help identify switch on road king
Old 02-10-2012, 07:24 PM
driv3rx's Avatar
driv3rx
driv3rx is offline
Default help identify switch on road king
I just recently got an '01 Road King Standard,on the back of the triple tree there are 2 switches,one chrome on the right side turns passing lamps on/off ,then there is a black plastic toggle switch on the left side,says on/off but I can not find anything coming on or going off when i flip the switch.any body know what it's for?It does have 2 wires leading from it but hard to tell where they go to.
Old 02-10-2012, 07:29 PM
pacemakertom's Avatar
pacemakertom
pacemakertom is offline
On my 04 RK it is a spare switch.
Don't know if this helps.
Tom
Old 02-10-2012, 07:32 PM
firefighter616's Avatar
firefighter616
firefighter616 is offline
probably wrong
but I think it's an aux switch that you can use for what you like
Old 02-10-2012, 07:34 PM
blupony's Avatar
blupony
blupony is offline
5th Gear
It's an aux switch that does nothing from the factory. The other end is behind the panel under the seat. I have mine connected to a 12v outlet to charge my cell.
shakrr's Avatar
shakrr
shakrr is offline
I loved watching the 3 stooges when I was a kid
Old 02-10-2012, 07:39 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Its for the coffee maker!
Old 02-10-2012, 08:06 PM
dibe's Avatar
dibe
dibe is offline
There is a 4 pin deutsch connector under the seat that you can connect an accessory to and that switch will turn it on and off.
I just wired up a USB plug to mine yesterday.
Old 02-10-2012, 08:45 PM
driv3rx's Avatar
driv3rx
driv3rx is offline
thanks for replies makes sense
Old 02-11-2012, 06:49 AM
ericl's Avatar
ericl
ericl is offline
If you don't mind, what u gonna do with the USB plug?
Old 02-11-2012, 07:15 AM
rhlhamlet's Avatar
rhlhamlet
rhlhamlet is offline
Extra switch for whatever you hook up to it.
Quick Reply: help identify switch on road king
