Stage one question
especially if you have a catalytic convertor in your headers, you will be ok.
alway good to post year model, modifications when asking a question as things change from year to year.
with the cat in place, there is a major restriction to flow- if you were to remove the cat or change headers, then you may want a tuning solution.
some bikes do, some don't.
for tuners, there are the add on units like the power commander, a download from Harley or I use nightrider.com XIEDS--- which for $125 are the perfect solution for me.
you need to be able to recognize if your motor is not running well, a real sign is "pinging" which is pre-ignition- this is audible as a sound like pebbles rattling in a coffee can on swift acceleration or go up a steep hill.
In my case ( 09) my motor pinged when factory stock under certain repeatable conditions ( 2800~3200 rpm up 6% grades). XIEDS solved that and I was later able to add the hi flow intake and exhaust with no ill effects
Mike
Mike
As I understand it, the ECM will "learn" to compensate for the lean condition in open loop mode, but not in closed loop mode, where most riding occurs.
GymChamp
11-09-2009 05:39 PM
