On a scale of 1-10, how hard is a complete exhaust swap on a 2012 FLHX?
Old 02-08-2012, 10:52 AM
Nicky Pass's Avatar
Nicky Pass
Nicky Pass is offline
Default On a scale of 1-10, how hard is a complete exhaust swap on a 2012 FLHX?
After thinking about it and looking everything over, and with the help of my friend the sport bike races, I've decided to do the exhaust install. How hard is it....?
Old 02-08-2012, 10:59 AM
RollaMo's Avatar
RollaMo
RollaMo is offline
With 10 being the hardest, I would rate changing exhaust about a 2
Old 02-08-2012, 11:07 AM
EastSideBikerTrash's Avatar
EastSideBikerTrash
EastSideBikerTrash is offline
The most difficult part is making sure the head pipes are seated properly so that you don't have exhaust leaks or cause the exhaust gaskets to restrict the exhaust flow.
Old 02-08-2012, 11:08 AM
SmittyFXDL's Avatar
SmittyFXDL
SmittyFXDL is offline
Old 02-08-2012, 11:11 AM
hoethree's Avatar
hoethree
hoethree is offline
LOL! Well that just depends on YOUR ability doesnt it? For me, somethings might be a 2 but for you a 10, or vice versa. Seems like every time I try to do anything for the first time, I later find out how I did it wrong or could have done it better or faster. Experience is the BEST teacher. Good luck on your swap out. Now if I can just get this thingee back in there with that other thingee......
Old 02-08-2012, 11:16 AM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,844 Likes on 19,331 Posts
I would rate it at about a "Twelve Pack" ... of course that's just me ... your results may vary! Actually it's not a tough job ... just take your time and use some common sense ... if you run into a problem, think it through ... you'll be fine!
Old 02-08-2012, 11:20 AM
XARAN's Avatar
XARAN
XARAN is offline
For most it would be very easy a 2 or 3. Requires basic tools, its easier if you have a helper to hold the pipes up in place when seating the headpipes and dont tighten everything up until it is all fitted on the bike.
Old 02-08-2012, 11:36 AM
JD_FLHX's Avatar
JD_FLHX
JD_FLHX is offline
Timely post! I just received my 2-2 Big Radius pipes and wondered about the same thing. As another source of info, I found this video on youtube, It shows a true dual install of bub headpipes and rinehart slipons.
http://www.youtube.com/watch?v=XIdXp...HtLfO1UrvjJWcL
Old 02-08-2012, 11:47 AM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,301 Likes on 781 Posts
Swapping the exhaust is comparable to the ability to actually ride a motorcycle.
Old 02-08-2012, 12:04 PM
rg_dave's Avatar
rg_dave
rg_dave is offline
No more than a 2.
Quick Reply: On a scale of 1-10, how hard is a complete exhaust swap on a 2012 FLHX?
