Rear shocks
Old 02-08-2012 | 12:26 AM
greg09997's Avatar
greg09997
Picked up a set of 13" take offs here on the Forum. Better ride and it also seems like it corners better too.
Old 02-08-2012 | 12:54 AM
BLKBAGGER's Avatar
BLKBAGGER
12.5" Progressive HD412s work great for what you are looking for. I have toured 2 up loaded with great results. I had the 440s before the 412s and had better results with the 412s. For the money they are great shocks.
Old 02-08-2012 | 01:15 AM
iwillfixthem4u's Avatar
iwillfixthem4u
I went with the stock 13" EG shocks and feel it was a big improvement. I happen to have another set in unopened factory boxes, PM me if you are interested. 2010 street glide
Old 02-08-2012 | 01:51 AM
drukanfu's Avatar
drukanfu
I went to the 13" EG shocks and it made a World of difference, then went to the 13" Ricors so I don't have to mess around with air pressure and they ride even better !
Old 02-08-2012 | 02:09 AM
Deuuuce's Avatar
Deuuuce
Went to 13"s myself, improved the ride, didn't hurt the budget for around $120 shipped off eBay for new takeoffs. Riding 2-up, at 50psi, definitely helped.
I read the spec from Cycleworld, the standard 12" shocks on the new SG/RGs have 1.9" of travel. 2.9" really made a difference.
Regarding the height - so you see a little of the rear rotor, big deal. You won't even notice later. Makes filling the tire a little easier anyway if you do it on the floor.
Old 02-08-2012 | 08:13 AM
UltraDune's Avatar
UltraDune
I put a set of Progressive 430 Series on my '11 RGC. The stock ride was real harsh so I went up 1" from stock on my bike, so 13's I guess. I have the 'HD' springs which can be kinda stiff solo if not adjusted right, but 2-up it is a huge improvement. For what I paid for them on Dennis Kirk I can't complain at all. Now to address the front end...
Old 02-08-2012 | 01:06 PM
monumaker's Avatar
monumaker
Originally Posted by skratch
the progressive 940 is supposed to give you the 13'' ride with a 12'' stance..... might look into that.
That's what I got and I love um.
Old 02-08-2012 | 01:18 PM
baust55's Avatar
baust55
i could use a set of 12" or the newer 11.5 StreetGlide shocks ... i am short . ha ha
Old 02-08-2012 | 01:41 PM
iclick's Avatar
iclick
Originally Posted by jrdfatboy
I am tired of the rough ride on my 07 Street Glide.
Sounds familiar. I tolerated my stock shocks for a few months and after trying some Progressive 440's I ended-up with Ohlins 2-3's, which transformed the ride to levels I thought were unattainable. They are not cheap, so if you want an economical solution I would find some used 13" stock EG shocks on Ebay, which usually go for around $50, and sell your 12" SG shocks. You may be able to break even.
If you do buy stock air shocks on Ebay, make sure the seller seals the air connection hole, because if not the oil will leak out. There is no official procedure for replacing the fluid, and HD says to replace the shock, but you can make a jig that will do the job.
Old 02-08-2012 | 01:56 PM
JimmyDee's Avatar
JimmyDee
jrdfatboy.....I have a 2008 SG and also want to keep the stock 'low' profile, but wanted a better ride.
When I had this conversation with Howard at Ohlins last week he suggested the Ohlins 2-2A. It has basically the same height as stock but with more travel. Howard is a real nice guy and not only knows his product, he also knows how it will effect your bike.
Quick Reply: Rear shocks
