1995 Electra Glide Tourpack
You can remove pretty easily with wrenches in about 30 minutes.
disconnect wiring
remove tour pak from mount bracket
remove bracket from frame mounts
admire the sleek-ness
then sort out the lic. plate mount, and hide the wiring under the seat.
I don't think the detachable hardware kits from Harley work on the '95, I looked into it about 10 years ago for my '95
Mike
disconnect wiring
Mike
The later kit won't work, but as Mike points out your tourpak can be got off fairly easily. Once you have done that get yourself a qd electrical connector and wire it in, so next time it will take just a few minutes.
Dirtywetdog
02-18-2014 07:39 AM
