H-D Security System Question
The marrying procedure is pretty simple to do by your self. I found the instructions on another forum. It was suggested that you hook up a battery charger while you do it, you have to leave the ignition on for 30 minutes or so to complete it. I'll see if I can dig up the instructions. It should have the auto arm setting, which will self-arm after turning off the ignition, then use the fob to disarm it to start the bike.
You can also try this link. Might be easier to follow.
http://www.ehow.com/how_7456283_prog...-davidson.html
