Header Pipe Swap
If you have the O2 sensors to monitor and enable the ECM to slightly correct AFR to keep the bike running within the specified map parameters, why not use them?
A word of caution with respect to any adapters for the new smaller O2 sensors...the 12mm sensors are very short and must be far enough into the exhaust stream to work.
2010 and later models extend the sensor into the exhaust only about 3mm and a reduction of just 1mm is enough to cause problems. A 2mm reduction could render the sensors useless and that might cause error codes.
So these adapters may not be an easy fix and may actually cause issues.
While most appreciate saving money, some of these "devices" could cause you to spend more dollars in the long run.
haman66
Exhaust System Topics
06-10-2013 01:23 PM
