Header Pipe Swap
Old 02-05-2012 | 05:41 PM
flamedking's Avatar
flamedking
Dawg6..the guys at night rider have the solution for running 09 pipes on you bike. Inexpensive too. Around 30-35.00. I have a set still in package I will sell you at a discount. Look on their website , if interested let me know.
Old 02-05-2012 | 05:47 PM
mjb765's Avatar
mjb765
What product are you talkiing about??? An 09 pipe bolts right on to his bike
Old 02-05-2012 | 06:06 PM
flamedking's Avatar
flamedking
O2 sensor re- locate. Other than that they sure will...
Old 02-05-2012 | 06:15 PM
mjb765's Avatar
mjb765
that could work.....
Old 02-05-2012 | 07:29 PM
DAWG_6's Avatar
DAWG_6
Originally Posted by mkguitar
while you are at it, check the tranny trap door bolts, the new spec is 25 ft lb.s.
esp the 2 bolts holding the exhaust mount have been backing out
locktite too
mike
Roger that.....I had a weird chirpping sound on decel on an '07 I rode and it turned out to be a frame bolt beneath the right side cover.....I'm coming up on 1K pretty soon and I'll go from front to back torquing everything to spec....
Thanks all.
Old 02-05-2012 | 07:37 PM
DAWG_6's Avatar
DAWG_6
Yeah, I saw that in another thread...but I really like the x pipe after reading their info and several other threads.....I will probly buy that first before summer hits so I don't roast the right side of the world when I ride....it's hotter than hell down here in Dallas/Fort Worth and last summer was a beast.....
Well, after checking out their site, that would be an easy fix.....so do you put the bung 'adaptors' in the old '09 holes and the smaller sensors fit into them??
Old 02-05-2012 | 08:01 PM
flamedking's Avatar
flamedking
Yes....take right side cover off, you will c where sensors plug in...install new bungs in header, then o2 into bungs. All plug up...simple.
Old 02-05-2012 | 08:11 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Veteran: Marine Corp
Originally Posted by DAWG_6
...Well, after checking out their site, that would be an easy fix.....so do you put the bung 'adaptors' in the old '09 holes and the smaller sensors fit into them??
A word of caution with respect to any adapters for the new smaller O2 sensors...the 12mm sensors are very short and must be far enough into the exhaust stream to work.
2010 and later models extend the sensor into the exhaust only about 3mm and a reduction of just 1mm is enough to cause problems. A 2mm reduction could render the sensors useless and that might cause error codes.
So these adapters may not be an easy fix and may actually cause issues.
While most appreciate saving money, some of these "devices" could cause you to spend more dollars in the long run.
Old 02-05-2012 | 08:12 PM
DAWG_6's Avatar
DAWG_6
Thanks...so the cord is just an extension for whats already there?
Old 02-05-2012 | 08:24 PM
flamedking's Avatar
flamedking
True, true pinetree, so you guys can understand my concern when I took out sensors completely with the PCv. I was like, really???? But hey, I learn something new almost every day... Works great.. and yes they are just extensions...
Quick Reply: Header Pipe Swap
