Outer cam bearing thrust washer O ring?
Getting ready to do the hydraulic tensioner upgrade and new cams in my 04 Road King. Instructions for the kit say to install the o ring, thrust washer, and bearing inner race onto rear cam. From what I can see this was already done by the cam manufacturer, as this is how it came out of the box. I guess I'm a little confused because the way the instructions are written, it seems like there is an o ring inside the thrust washer, which I obviously can't see. There is also an extra washer in the package with the rest of the roller bearing. I will post pics to try to explain what I'm talking about. I assume everything here is normal, just someone please give me an idea of what it is exactly that I'm looking at here. These are Head Quarters cams by the way.
I'm with Tinman, those look like the old style chain drive cams not the hydraulic cams. You mentioned you were switching over to the hydraulic tensioner setup which would mean a new style cam plate and those cams don't work with it. The chain sprocket on the hydraulic setup is not as wide as the old style. Here is an example from Andrews website. Correct me if I'm wrong please.
http://www.andrewsproducts.com/PDF_f...onCams-pg5.pdf
http://www.andrewsproducts.com/PDF_f...ams99-pg11.pdf
Rick
If you just want to get rid of the spring loaded tensioners and get the higher volume oil pump this is a good way to go. The other option is to replace everything with the 07 up parts but then you need the "N" version cams as you had mentioned.
Rick
I've checked into doing the conversion, cause i just don't want to buy a new bike to get it, and know about the N cams but right now isn't a good time to make plans money wise, fixin to get divorced, if you know what I mean.
