How to enlarge small gauge hole in fairing?
02-03-2012, 05:29 PM
I need to enlarge one of the small 2" gauge holes in my faring about 1/16 to 1/8 inch for aftermarket gauge.
Anyone have a good/easy method to do it?
Thanks
02-03-2012, 05:42 PM
Sanding drum on a Dremel tool.
02-03-2012, 06:22 PM
02-03-2012, 09:31 PM
Masking tape and keyhole saw/drillbit... choose whatever exact diameter you need.
02-03-2012, 09:39 PM
02-03-2012, 10:07 PM
Quote:
Originally Posted by
agapsdiver
Thanks
2 inch 12 gauge seems appropriate - just vary the distance
02-03-2012, 10:24 PM
Pelonz
Step drill
+1
This is the cleanest
02-04-2012, 07:30 AM
silverado636
I'd agree. Considering what your trying to do a step drill won't be big enough and a hole saw would be uncontrolable.
02-04-2012, 07:37 AM
I'd use a 1 7/8" drum sander and a slow speed drill motor to enlarge a 2" hole in plastic or fiberglas.
02-04-2012, 07:45 AM
The gauge holes have a notch that might catch a step drill, and a 2" step drill is not a common or cheap tool. Slow speed sanding drum is a very good idea, if you got more time than money a coarse half round file should do the trick also. What gauges you using, always interested in real custom mods?
