trans exhaust bracket issue 06 SG
I have aftermarket big radius style pipes on my 06 SG. I'm going to switch them out for vanson hines pro pipe. The exhaust bracket for the radius is completely different than what I need to properly mount the pro-pipe. Has anyone had to change their exhaust bracket? What does it take to do it? any help would be great.
If it is this set up
http://partsfinder.onlinemicrofiche....dmc&A=470&B=45
(#33) the bracket is bolted to the two starter bolts. Remove the bolts, leave the starter in place and remove the bracket. Replace bolts trq to 13-16 ft.lbs. V & H insructions step 11. If it is #28 the V & H instructions step 12 cover removal of the stock HD bracket. http://www.vanceandhines.com/store/t...llsystem/26045
