Notices
Mid frame heat deflectors
Old 02-03-2012, 08:37 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
i used the rj"s go on easy stay on don't crack or fade,and u can easily reach the backrest adjuster,american made (all vet company) with all american materials.
Old 02-03-2012, 10:23 PM
dlongo8241's Avatar
dlongo8241
dlongo8241 is offline
I will say that I snugged the bolts pretty good, but I'd put money that under those metal top clips that (are covered anyway) the paints all chewed up and scraped away, no way around it....I bet the ultras that have them factory installed have to be the same way......tight metal clips and painted metal don't mix that well.......
Old 02-03-2012, 11:54 PM
CT-Bagger's Avatar
CT-Bagger
CT-Bagger is offline
Originally Posted by DannyZ71
One thing you can use on nuts and bolts that will work like thread lock is wax. I learned this old trick while shooting archery as the points were always loosening up from the inserts in the arrows. Works great as a thread lock while also working as an anti-seize.
Wax will never take the heat under there. It will drip away and be gone after the first stop light.
Old 02-04-2012, 09:54 AM
troop's Avatar
troop
troop is offline
I gotta admit, the painted ones look sweet. But I opted for painless/easy, albeit more $$, for the Capt Itch deflectors. They can come off very easy for cooler spring/fall rides when more heat is appreciated....
Old 02-04-2012, 01:01 PM
PDDGM's Avatar
PDDGM
PDDGM is offline
RJ's are the best. Nothing to paint, no pain in the *** fastners. Match the seat. Their so good HD would copy them if they could.
Old 02-04-2012, 02:01 PM
Ultra89Rider's Avatar
Ultra89Rider
Ultra89Rider is offline
Originally Posted by baust55
i got the Captain Itch Crotch Cooler for my 2008 FLHRC looks great ! damm nice well made product.
Originally Posted by santajim
Do yourself a favor and get the crotch coolers from Captn. Itch. They are freakin' awesome.
Originally Posted by troop
I gotta admit, the painted ones look sweet. But I opted for painless/easy, albeit more $$, for the Capt Itch deflectors. They can come off very easy in summer heat ...
I just don't like the look of the Capt Itch unit. It has the look of just "thrown over the frame" clutter.
IMO it just takes away the clean look of the ride and directs you to look at the deflector.
If I ever install a shield, I want it to just fade away and not look like it is the center of attention.
Old 02-04-2012, 04:55 PM
dlongo8241's Avatar
dlongo8241
I agree... that why I got the factory ones, they look like they belong plus like another poster said it hides that space in the rear fir a cleaner look ......
Old 02-04-2012, 05:11 PM
DeneFXDWG's Avatar
DeneFXDWG
DeneFXDWG is offline
They do look like a thrown over pice that doesn't fit in but I haven't seen one in person so my opinion might change. Do they rub on the covers on both sides, look like they come darn close? I agree the factory ones look more like they belong.
Old 02-04-2012, 05:14 PM
dlongo8241's Avatar
dlongo8241
if you are asking about the factory ones, then no they don't rub at all. DL
Old 02-04-2012, 07:34 PM
DeneFXDWG's Avatar
DeneFXDWG
No DL, I was referenceing the aftermarket ones. I know the proper factory ones don't rub. Thanks
Quick Reply: Mid frame heat deflectors
