road king classic fuel help
Old 02-02-2012, 06:49 PM
Anabolic's Avatar
Anabolic
Anabolic is offline
6th Gear
Default road king classic fuel help
where can i find a 90 degree angle barb in place of the quick disconnect fittings?
Old 02-02-2012, 07:46 PM
hogfun's Avatar
hogfun
hogfun is offline
Not trying to state the obvious but if it is fuel injected you should not use barbed fitttings... the fuel lines are under presure that barbed fittings and worm gear clamps cannot hold.
Otherwise, you can check with NAPA, Fastenal, Lawson Products, etc... for fittings.
Old 02-03-2012, 08:14 PM
Anabolic's Avatar
Anabolic
Anabolic is offline
6th Gear
do you know the thread pitch?. it's not a pipe thread
Old 02-03-2012, 08:17 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
on the other end of the quick coupler is a barb fitting with a cheep constant pressure clamp so yes you could replace it but why. Just curios.
Old 02-04-2012, 01:08 AM
Anabolic's Avatar
Anabolic
Anabolic is offline
6th Gear
well i took thje fitting out, i don't like the fact as soon as you touch them they leak and you have to replace the o rings everytime, with the right size barb the hose shouldn't come off even without a clamp added for security... anyone know where i can get the thread pitch for the tank with the barb?.. eaither 90 or 45*? would aeroquip make that? any links?
Old 02-04-2012, 05:28 PM
Anabolic's Avatar
Anabolic
Anabolic is offline
6th Gear
anyone? this is rather important.
Old 02-04-2012, 06:58 PM
soft 02's Avatar
soft 02
soft 02 is offline
Monday i can check my Areoquip and other hyd books to check for fittings.
Old 02-05-2012, 05:35 PM
Anabolic's Avatar
Anabolic
Anabolic is offline
6th Gear
thankyou! i don't know tjhe thread pitch , i would attempt to find something myself but no such luck yet unless i mod the original peice/take it apart
Old 02-06-2012, 03:57 PM
Anabolic's Avatar
Anabolic
Anabolic is offline
6th Gear
any luck soft?
Old 02-06-2012, 05:11 PM
soft 02's Avatar
soft 02
soft 02 is offline
I couldnt find a strait thread to 90 barb. The best I got was an adapter from male straight thread to female pipe. Then you can use normal hardware for the rest. I need to spec mine to get the correct size for the straight thread portion. Totaly forgot but got a note written down now!
Quick Reply: road king classic fuel help
