Torx vs. Torx +
The #1 cause of people stripping the head is because they use a T25 instead of the T27 size that it is.
T27 bit does not come in most smaller tool sets.
The T25 that does come in those sets, will fit (but its not a tight fit).
So, when you try to put any pressure on it it will strip the head.
Or you can go to Sears (Craftsman) and buy a single T27. Not cheap, but WAY better than the alternative.
Cheap tool are a bad idea anyway.
Location: Western Illinois, land of bad roads, and corrupt politicians
In a previous thread, it was stated that they are a T+, but when I went to try to get a T+ nobody, including the local dealer, had heard of them. After stripping a couple using a T25 (see above) I did get a T27 bit and that, together with antisieze on the bolts, has resulted in a problem free status since.
