Torx vs. Torx +
A Torx variant, Torx Plus, introduced about 1990 when the original Torx patent was expiring, is designed to allow greater torque, and to minimize wear.[7] The specifications for these licenses are held by Textron. Standard Torx drivers can be used to drive Torx Plus screws, but not to full torque because of the loose fit. Torx Plus drivers will not fit standard Torx screws. They are shortened to "Torx TX".
Like everything else know what cha have and use the right tool for job. But if that fails use a BFH ( big phking hammer).
never heard of torx+????
Could someone explain what a torx+ is?
How about pictures?
I have been in the auto industry for 30+ years and never heard of this.
I spent 3 years selling Snap On in the early 90's.
Never heard of torx +.
As said previously you need to have the correct size and there will be no issues removing the derby cover.
Not wanting to be a jerk to previous posters but please explain.
How about pictures?
How about pictures?
How about pictures?
The #1 cause of people stripping the head is because they use a T25 instead of the T27 size that it is.
T27 bit does not come in most smaller tool sets.
The T25 that does come in those sets, will fit (but its not a tight fit).
So, when you try to put any pressure on it it will strip the head.
Torx vs Torx Plus
How about pictures?
How about pictures?
