HD 12-disc CD changer question
Old 01-30-2012, 01:25 PM
kabuelich's Avatar
kabuelich
kabuelich is offline
Stage III
Default HD 12-disc CD changer question
I just acquired a 2000 Ultra with stock AM/FM/ CB/Cassette and it has the 12-disc changer in the trink with handlebar -mounted controls and amplifier mounted under the trunk. THe CD unit appears to be working, loads discs , etc but I do not hear anything. Can anyone tell me how to set the in-dash unit to the right mode to hear it? AM,FM,cassette all work fine. If anyone has an operators manual for the disc changer, that would be great!
Old 01-30-2012, 01:38 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
this may not help...some units play back through the FM radio via a modulator.
try getting the CD playing, then turn on the FM radio and scan the channels
or get a CD playing and change modes and see if CD becomes an option to select once it is on and running
Mike
Old 01-30-2012, 02:39 PM
mfortkamp's Avatar
mfortkamp
mfortkamp is offline
Im with mkguitar i had a 95 Grand prix with a 10 disc in the trunk and it was the same way. My changer had a switch on it so you could go between a couple different stations. I would also look to see if the radio has an aux input, as it may be feeding through there as well,
Matt
Stephen D
Audio Systems
08-27-2013 04:17 AM
Jim Dawson
06-24-2012 07:05 AM
SGT89EVO
EVO
11-29-2011 07:18 PM
HiTech
09-28-2009 05:24 PM
gearheadfmc
07-07-2006 03:41 PM
Quick Reply: HD 12-disc CD changer question
