Question about head pipes?
Old 01-30-2012, 12:24 PM
nuhklz's Avatar
nuhklz
nuhklz is offline
Originally Posted by Ronp42
...To answer the OP's question. I've been both route's with exhaust. If I were going to gid rid of the cat, I would spend the money and get a FuelMoto headpipe or Fulsac X-Pipe. There's been a lot of question's about Cross Talk between the 02 sensor's with the cat removed from the stock header. Plus you will gain maybe 5 HP with a tuned header. JMO
+1 on the cross talk. I de-catted my head pipe and couldn't get the bike tuned right using TTS with all kinds of popping and backfiring. I put on the fuel moto x-pipe and the bike tuned right in and runs like a champ.
I'm not looking to start a debate but just sharing my experience.
Old 01-30-2012, 12:57 PM
DXHD $100's Avatar
DXHD $100
DXHD $100 is offline
I didnot have any problems I quest because when I gutted mine I installed an Autotune at the same time.
Old 01-30-2012, 01:04 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,301 Likes on 781 Posts
Originally Posted by yoyoman05
i have a 2011 sg with a stock head pipe.. i was thinking of gutting the cat..was it hard to do?..do i have to get it retuned afterwards.. ?. i already have a se stage one download on it with a set of se supertrapp slip ons
Not hard to do. I used a Saws All to cut the pipe in half, drilled several hole in the CAT material and then beat it out with a chisel. Used a wire brush on a drill to clean out the rest of the material and had a welder weld it back up. Cost me $35 for the weld job and another $35 for gaskets and clamps. My bike is stock so no tune is required. Your situation could be different than mine.
Old 01-30-2012, 01:16 PM
RAYCE_FLHP13's Avatar
RAYCE_FLHP13
RAYCE_FLHP13 is offline
Well then maybe I will just buy an aftermarket head pipe. Not the route I really want to go but i would rather spend the money up front than triple that later because something went wrong. Thanks for all the info guys. If you've got some aftermarket exhaust for sell shoot me a PM or you can find me surfin the classifieds.
Old 01-30-2012, 01:21 PM
skratch's Avatar
skratch
skratch is offline
Received 4,371 Likes on 2,543 Posts
is it possible that you had the o2 sensors backwards and then when you switched out the headpipes you got them in right?
not being snarky, just asking....
no problems with my 2010 decatted.
Old 01-30-2012, 02:50 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Originally Posted by RAYCE_FLHP13
So I'm in the market for some new exhaust. I've found lots of good deals on here but have a question... is there a difference between a gutted 2010 stock head pipe vs. An aftermarket head pipe? I'm not too worried about power gains but more about a truer/deeper Harley sound. More noise if I add some slip ins or a full stage 1 setup.
I have a 2:1 2010 OEM system that came off a SG, have used the the OEM muffler with the FM headpipe and the OEM headpipe with the cat, didn't notice any significant noise difference, or power difference. Supposedly removing the cat makes them louder but I have no personal experience with a decatted OEM pipe. For that "truer/deeper Harley sound", you could just try a larger muffler and/or a bigger baffle.
Old 01-30-2012, 03:37 PM
RAYCE_FLHP13
I'm planning on new mufflers but I've heard a lot of slip ons with the cat and they're not really loud enough for me. I want something that I can hear while driving down the highway with my helmet on... so I thought if I gut the cat.maybe it would then be loud enough for me. Plus I'm gonna di a stage 1 soon so if I needed head pipes I would just throw that into the cost.
Old 01-30-2012, 04:37 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Like I said I got no personal experience with the decatted stock pipe. I've seen a lot of people post that it was definately louder after removing the cat. No gurantee you will achieve the sound you're looking for with the first set up you try.
Old 01-30-2012, 05:57 PM
kojak's Avatar
kojak
kojak is offline
Received 2,808 Likes on 1,362 Posts
Personally, I would treat removing the cat just as if I had installed new, free flowing headers. You are greatly reducing back pressure and impacting all kinds of engine dynamics that live off reversion, scavenging, compression ratio etc. I would definately get a ecm remap.
Old 01-30-2012, 06:16 PM
stewy1200c's Avatar
stewy1200c
stewy1200c is offline
The First thing I would do is to buy a stock headpipe off the internet or this site's classified. Thats what I did for $75 bucks shipped.That way you can still have your stock pipe if the govt gets stupid. Then I removed the cat and added slip-on's. There are a lot of threads here that will show you step by step. Its not hard to do, I had my buddy who owns a bike shop tig weld it back together. Its not a performance booster, but WITH the slip-ons the sound is much better. The bike is for sure cooler with the right side leg test. I also did a SE air cleaner and Fuelpak. NO cross talk with O2 senors. Have over 9000 miles since the de-cat. The sound will be even better with true duals, but Im very happy with $75.00 I have in it.
Quick Reply: Question about head pipes?
